Doom
Publisher: Bethesda Softworks
From our
Doom review:
Mainly though, it’s the single-player that revives Doom’s fortunes, which makes for a refreshing reversal of the norm for FPS’ these days. Even thinking about it as I write this gives me a little buzz of adrenaline, such is its incredible intensity and pace. There are mistakes, and I wish it brought a little more that was new to the fore. Nevertheless, the quality of Doom’s core combat is undeniable, and I doubt there’s a beating heart in the land that will remain steady when the portals of Hell open this time around.'
Doom is unique amongst our benchmarks for its use of the Vulkan API - OpenGL is also supported, but it's Vulkan that we're interested in benchmarking. FRAPS does not work at all with Vulkan, and though Doom has built-in performance metric monitoring there is no means of recording it. As such, we use
PresentMon, an Intel-made Event Tracing for Windows (ETW) FPS monitor. Its command line interface and .csv results output make it fussy and time-consuming, so we also utilise the nifty
PresentMonLauncher application that adds a basic GUI and a results analyser that gives you minimum and average frame rates - a big shout out to Andrew at
TechteamGB and Jim at
AdoredTV for their work on this. Recording in this way does appear to have a small performance penalty, but this affects all cards in a roughly equal fashion and is currently the best means of benchmarking Vulkan performance. We benchmark a 30-second manual run through an early part of the game that we found to be relatively demanding and also repeatable. It involves plenty of running, an explosion and blasting demons to smithereens - exactly what you'll be doing in-game.
        Sapphire Radeon RX 470 Nitro OC 4GB
        Gigabyte GeForce GTX 1060 WindForce OC 3GB
        MSI GeForce GTX 1050 Ti Gaming X 4GB
        Gigabyte GeForce GTX 950 OC 2GB
        Gigabyte Radeon RX 460 WindForce 2X OC 2GB
Frames Per Second
Frames Per Second
